Upgraded wheels options via www
    Cut & pasted .., SUR RON-X-LB Woody Wheel Works
    View full product details
    Choose Riding Style. --Off-Road Maven - 21/18 Dirt Bike Setup or19/16 Ex-off-road Style -
    --- Off-Road Maven--21-front--18 rear.
    Choose Front Rim Off-Road Maven
    -Excel One/Rex Rim 21x1.60 (silver) - $129.00
    -Excel One/Rex Rim 21x1.60 (black) - $129.00
    -Excel 7000 Series Rim 21x1.60 (silver) - $149.00
    -Excel 7000 Series Rim 21x1.60 (black) - $149.00
    -Excel 7000 Series Rim 21x1.60 (blue) - $159.00
    -Excel 7000 Series Rim 21x1.60 (gold) - $159.00
    Constructed from an aluminum alloy, the Excel Takasago 7000 Series Rim is light, strong and geared for off-road performance.
    M Pro Platinum Rims are also made from a lightweight aluminum alloy for strength and durability. The 19/16 dirt bike style geometry makes for a "big wheel" feel while riding. We recommend a 70/100 tire for the 19x1.40" rim.
    Other front Rim Dirt Bike Setup-- Choose Front Rim Dirt Bike Setup.
    -SM Pro Platinum Rim 19x1.40 (silver) - $129.00
    -SM Pro Platinum Rim 19x1.40 (black) - $129.00
    -Excel Takasago 7000 Series Rim 19x1.85 (silver) - $129.0
    -Excel Takasago 7000 Series Rim 19x1.85 (black) - $129.00
    -Excel Takasago 7000 Series Rim is stout and light, constructed from 7000 series aluminum. The SM Pro Platinum is made from 7050 series aluminum for toughness and durability as well. Both rims offer significant strength upgrades over OEM rims for increased off road performance while retaining OEM handling. The narrower 1.40" rim allows you to run a 70/100 tire.
    Front Rim OEM Style Setup-- Choose Front Rim OEM Style Setup.
    -Excel Takasago 7000 Series Rim 19x1.85 (silver) - $129.00
    Billet hubs are CNC'd from a single piece of lightweight aluminum for strength and durability.
    Reusing your OEM hub requires that you ship the hub to us.
    Front Hub Off-Road Maven.
    Choose Front Hub Off-Road Maven --Billet Hub - $99.00 or Reuse Your OEM Hub.
    Reusing your stock OEM hub requires that you ship the hub to us.
    Front Hub Dirt Bike Setup-- Choose Front Hub Dirt Bike Setup --
    Billet Hub - $99.00Reuse Your OEM Hub
    Front Hub OEM Style-- Choose Front Hub OEM Style .
    Excel's Takasago 7000 Series 18x1.85" and 18x2.15" Rims are constructed from 7000 series aluminum for unmatched strength and durability.
    The 18x1.85" wide rim pulls in the tire to create a rounded profile for better rim protection and off-road performance.
    The 18x2.15" wide rim is best suited for mixed pavement and off-road riding, and will not create as much of a rounded profile on the tire. .
    We recommend a 3.5x18 enduro style tire for these rims.
    18" Rear Rim. Off-Road Maven-- Choose Rear Rim Off-Road Maven.
    -Excel 7000 Series Rim 18x1.85" (silver) - $159.00.
    -Excel 7000 Series Rim 18x1.85" (black) - $159.00.
    -Excel 7000 Series Rim 18x1.85" (gold) - $169.00.
    -Excel 7000 Series Rim 18x2.15" (blue) - $169.00
    Excel's 7000 Series Takasago 16x1.85" Rims are constructed from an aluminum alloy for weight savings and toughness.
    The 16x1.85" wide rim pairs well with the 19" front wheel to create a dirt bike style geometry and improved off-road handling.
    We recommend a 90/100 size tire for this rim.
    16" Rear Rim Dirt Bike Setup-- Choose Rear Rim Dirt Bike Setup.
    -Excel 7000 Series 16x1.85" (silver) - $139.00
    -Excel 7000 Series 16x1.85" (black) - $139.00
    The 19/19 OEM Style setup is designed to improve your overall wheel strength while retaining that OEM feel.
    Excel's Takasago 7000 Series Rim is stout and light, constructed from 7000 series aluminum.
    Both rims offer significant strength upgrades over OEM rims for increased off road performance.
    Rear Rim OEM Style Setup-- Choose Rear Rim OEM Style Setup -
    -Excel Takasago 7000 Series Rim 19x1.85 (silver) - $129.00.
    An enduro style tire, like the Shinko SR241, fits the 19" or 18" rear without needing an offset.
    Knobby dirt style tires, such as the Dunlop MX33, will only fit on an 18" rear and require an offset and removal of the kickstand to enable chain clearance. When "1/8" Offset Required" is selected below, we will true the rim 1/8" away from the sprocket to provide chain clearance, and the kickstand will likely need to be removed.
    Rear Rim Offset-- Choose Rear Rim Offset --No Offset Needed1/8" Offset Required
    OEM hubs are factory spec. Reusing your OEM hub requires that you ship the hub to us.
    Rear Hub Off-Road Maven-
    -Choose Rear Hub Off-Road Maven --New OEM Hub - $119.00 or use Your OEM Hub
    OEM Hubs are factory spec. Reusing your OEM hub requires that you ship the hub to us.
    Rear Hub 16" Dirt Bike Setup-
    - Choose Rear Hub Dirt Bike Setup --New OEM Hub - $119.00 or use Your OEM Hub
    Rear Hub OEM Style-
    -Choose Rear Hub OEM Style --New OEM Hub - $119.00 or re-use Your OEM Hub.
    The Stainless Steel Spokes and Aluminum Nipples are heavy duty and will not rust, oxidize or seize. These are larger than OEM sizes and the best option for strength, durability and longevity.
    Spokes & Nipples*-- Choose Spokes & Nipples --Stainless Spokes & Aluminum Nipples
    (one wheel) - $119.52Stainless Spokes & Aluminum Nipples (two wheels) - $239.04
    Supersizing uses over-sized spokes and nipples to create a stronger and more durable wheel.
    Each hub is laced and trued to the rim with stainless spokes and aluminum nipples.
    2 wheel set
    19 " or 21' front rim ....$130.
    New front hub.................$100.
    18" 19" or 16" rear rim.$160.
    New rear hub............... ....$120
    Spokes & nipples.............$240.
    lace-& true.........................$222.
    = $952.00 plus shipping
    Don`t forget 2 new tires, HD inner-tubes and rimlocks
    Woody's is awesome. Just call them on the phone and they'll help you choose your setup.
    • dirtman
      dirtman commented
      I see Woody`s just updated his site with a Surron wheel section
      2 minutes ago I just edited the topic to make it EZ to see what I/we need to spend.
      Figure I`ll I get 2 new hubs from WWW and have spare stock wheels to save or sell.
    I sent in a front hub to Dubya Usa for a friend,with Excel rim 21 x1.6 he’s paying $290 + freight.Their getting slammed with orders too for Surron wheels.
      Wish they made a rear hub that had a six bolt pattern for mtb brake discs.
        If anyone is in the US and wants to sell me a set of stock 19” wheels I an interested.
          What condition of used stock 19" wheels are you looking for.??
          I started this thread back in March 2012. I intend to get 2 new wheels in the near future.
          My stock wheels are in very bad shape. Constant adjustment of the spokes & nipples. A bit out of true and a few bent spokes
          January, I installed 2 new knobby tires HD tube, rimlocks and a few spokes & Nipples.
          After a few more rides I intend to overhaul the complete rear drive system with a WWW 18" wheel.
            I was hoping for like new take offs if someone was upgrading.
