Front brake hose
    Front brake hose
    Has anyone else had trouble with the front brake hose bowing when the forks are compressed and rubbing on the tire?
    What is the solution?
    Thank you.
    A zip tie or two is the easiest
    there are brake cable guides available and if you have a 3d printer there are models out there.
Name:	front brake line.jpg
ID:	126210 This is the problem.
        How tight is that upper cable guide? (The cable should move freely through it) When I was running that fork I had to rotate that upper guide a little so that the cable wouldn't bind and flex like in your picture.
          Zip tie
            Thank you for the suggestions. The hose seems free in the upper guide but I will try the "loose" cable tie.
