Tension bolts
    Tension bolts
    Does anyone know the size and length of the Rear wheel tension bolt and nut. Mine are wore out .
    If you mean the rear axle,I bought one at Ebikezilla for the Surron
      The bolts that tighten the chain, the bolts that push the axle back until you get the right amount of chain tension. Thanks.
        should be M6x35 according to Sur Ron UK site.
        https://surron.co.uk/collections/sur...ar-swingarm-02
          Thanks you G
            Yours are worn out.? I assume you mean the male-bolt and not the female-treads machined into the swingarm.
            PS: Do you loosen the axel nut before attempting to adjust the chain.? The rear wheel should move freely within the swingarm.
              Yes I ajust the tension first then tighten the axle. The corners on the head of the bolts are rounded off a bit. So are the nuts. They still work but I would like to replace them. Is that something I could get at a Napa or O'Reilly parts store? Thanks!
              • dirtman
                dirtman commented
                I seen from another post of yours you have a 2018 SRX-LB.
                That shows your going on your 3rd of 4th season..
                I am going on my 2nd season and my second chain.
                I also noticed that my tension bolt have weak corners. and my 10-MM wrench slips off also.
                I`ll add 2 new high quality tension bolts to my list of future parts.M6x35
                Thanks Cosmic-G for the https://surron.co.uk/collections/sur...ar-swingarm-02
                That a UK site. Luna-Cycle-USA or any quality hardware store can get the bolts.
                PS Spark. 2018 SRX-LB. 3rd or 4th season.
                Any good or bad comments about the bike?
              Those are probably good places to look. I usually try Home Depot or Lowes, you can take your current bolt and use their thread gauge thingies to verify the thread pitch.
              • Spark
                Spark commented
                Thanks bro
              Buyers remorse.
                Has anyone found the bolts and nuts online? I'm stuck at home until I get my bike fixed. Having a hard time finding these, when it seem like a easy part to replace. Thanks
                  I can't confirm these fit but they look correct?
                  amazon link
                  • Spark
                    Spark commented
                    Thanks CosmicG
