Does anyone know if I need adapters to mount the calipers? Post or IS ? What specs do I need to know when ordering? Thanks!
Hope brakes
Depends on your combo.
Rotor diameter? Forks?
I'm using a 2019 Fox 40 and a Hope 225mm rotor up front.
The fork is ready for a 203mm rotor.
I pulled the adapter from the stock RST Killah fork and my wear pattern is spot on.
It did take some knocking to get the caliper straight tho.
If I knew what size the adapter was on the killah fork, I would order a quality name brand.
