I recently got one of the new sur rons and it came with the kke front fork and i was wondering is the kke forks better than the dnm and fastace forks or about the same
Thanks
I have a Sur Ron with a Killah, and a Segway with a DNM, and both perform reasonably well. I suggest you ride the bike with the fork you have and see if you want to spend $1k or more to upgrade.
A few days ago I bought an electric bike, it is the latest brand and its fork is a kke fork. It's also good and rides very smoothly with shock absorption.
i run the kke on my surron x. I just mistakenly landed in the flat tonight off an 8 foot jump. i didn't wash out or bounce off. It's not bad. play with the settings. the rebound won't be a problme. it's just the compression stroke you must be worried about. I've heard if you can't get enough resistance you can put mx shock oil in the compression tube. This is how motocross forks work. I have not validated this. Oh- check your air pressure first. bottom of the left fork. get a high pressure shock pump and experiment.
