Greetings,
As I live in Norway, autumn/fall and especially certain tunnels will be very dark. I would therefore like to mount a high beam to my Light Bee. The Speedo have a high beam indicator, which also turns on (blue) for a few seconds when I turn on the ignition, but I have not been able to figure out how to enable it, and no wires seems to be ready for it.
Do I have to play with the RS485? If so, anyone have the protocols needed to enable/disable this LED? It would be neat to have this indicator act with my high beam.
If not, I can use the 12V that goes to the USB charger (rated at 12V 1A), but then my other question is; what is the 12V converter rated for, and how much current is it giving to the rest of the system? Will I get any trouble if I for example pull 4A (3A more than the USB charger port)?
