Guys- i'm a dummy. i can't figure out where the Egg Rider V2 displays the motor temperature. I checked the manual. i'm overlooking it or the V2 doesn't dsiplay motor temp. that would be not good.
Egg Rider Display
Quinc. that's an unknown quantity. here is what i know. when i run my motor hard at 12kw it will heat up to 142 degrees at the hottest point on the case (the bottom). no problems yet. The green lne enginneering app has a cut off built in the app at over 100C. you can see it on their youtube video introducing settings on thier GLE app. That's 212F. That's crazy hot before cutoff. i'm running hard and no where near that. All this is still not an answer. when/if i blow it up i'll take the temp and let you know.....
- Likes 1
Quinc - the ASI Product sheet for 4k and 8k says this.... "The controller linearly reduces maximum output current when the internal controller temperature is above 80ºC. Complete cutoff occurs at 100ºC, the control board over-temperature threshold"
- Likes 1
