Circuit breaker
    Circuit breaker
    Luna is out of stock on breakers, anything out there to replace my always on unit’ 3 weeks old
    Go to EBay,under 125amp solar breaker din rail mount,seller is buycheapsolar.2 for 19.99 with free shipping,identical to the Surron breaker,same manufacturer
      American Surron claims to have them in stock: https://americansurron.com/products/...ircuit-breaker
        There also selling the EBay version,there photo is not the stock Surron breaker.
          That matches whats in my bike and its a 2022 model. Click image for larger version
            Here’s one from Luna Click image for larger version
              I replaced my original with one like yours but they both do a bad job of passing current ( voltage sag probably because of cheap conductors,I think their steel)
                My link shows a matching 100A CB. https://lunacycle.com/sur-ron-replac...rcuit-breaker/
                Is the 125A one better than the 100A one?
                • dirtman
                  dirtman commented
                  ""Is the 125A one better than the 100A one?""
                  ...Is.......125A......better than.........100A..?
                  P= E x I.
                  P-watts = E-volts x I-amps
                  ..........6000-watts =.. 60-volts x 100-amps
                  ..........7500-watts =.. 60-volts x 125-amps
                  Kguy ""they both do a bad job of passing current
                  (volt sag probably because of cheap conductors,I think their steel)
                I understand Ohms Law but putting a bigger breaker in does not jump the current up. A bigger breaker just means that a higher current rating is needed to blow it. So you're letting more current thru than the manufacturer specified. Which can be unsafe. If you want more actual amps, then you'll need a different battery.
                I guess I should have phrased it differently. Why do you think the 125A is better than the 100A?
                • Kauaiguy
                  Kauaiguy commented
                  I run 200amps thru my 125amp breaker and have never had it trip,I think they mostly work to prevent spark when connecting your battery up( while breaker is off).There steel connectors make for pretty good voltage drop at higher settings.
                • pismocycler
                  pismocycler commented
                  Most breakers are designed to run at rated current indefinitely. Many will run at 2X rated current for an extended period of time like 30 min, and for shorter periods of time as the current goes up. You need to know the actual specs for the breaker to know for sure.
