I am struggling riding my Sur Ron on rough varying conditions. When I slow down upon encountering a large boulder on an uphill rocky trail I am often thrown off balance on the bike because of the quick torque engagement. I can't seem to find a sweet spot where I can engage minimal throttle to creep ahead vs lunge forward and bounce off the obstruction. I read something about putting pressure on the rear brake at the same time as engaging the throttle. Can someone explain this to me or share other tips for riding thru rocky obstacles? I admit, I am a novice rider however I am considering going back to a bike w/a clutch so I can have the benefit of feathering the clutch. In the short time I learned on my 125cc bike I didn't seem to have this problem. Any advice is appreciated.
Sur Ron has too much torque!
Originally posted by mccallgirlie View PostI am struggling riding my SRX-LB. I admit, I am a novice rider however I am considering going back to a bike w/a clutch so I can have the benefit of feathering the clutch.
Originally posted by mccallgirlie View PostWhen I slow down upon encountering a large boulder on an uphill rocky trail I am often thrown off balance on the bike because of the quick torque engagement. I can't seem to find a sweet spot where I can engage minimal throttle to creep ahead vs lunge forward and bounce off the obstruction.
If you really believe that torque is the problem, torque to the tyre can be reduced by going to a smaller rear sprocket, try a 42.
If however minimum speed is the problem, go to a larger rear sprocket, possibly a 58. Torque will increase, but at the same throttle opening you will be going slower, which I think is what you're looking for.
Just ride for a while and adjust your style and approach. The electronic throttle sux, too glitchy esp near 18mph or so, cable version is cheap and a nice upgrade. The high torque available all the time, really makes it easy to pop the front wheel over an obstacle or ditch, never have to downshift for that.
I have a 60 T sprocket on my MX 4, the only one to do so it seems, not for more torque, but for less throttle twitchiness. My top speed is now 38-39, which i could care less about as most of my rocky and steep trail rides take place at single digit or slightly above speeds. It of course has HUGE amounts of torque.
Originally posted by CPG View PostI have a 60 T sprocket on my MX 4, the only one to do so it seems, not for more torque, but for less throttle twitchiness.
