Is there a tutorial on removing the the kickstand sensor?
Surron kickstand sensor
(filedata/fetch?id=147594&d=1644427658) NOTE: If you bike is new, make sure to read the unboxing article before read this (https://electricbike.com/forum/forum/knowledge-base/surron/55116-sur-ron-lightbee-documentation-specs-unboxing-and-initial-setup) Besides the wrenches and Hex keys you need to maintain your
There’s an image in post # 4 on this thread that should help. I’ll be removing mine in the next few weeks, and I’ll try to take a photo or two!
15 min with tools on hand, something like:
Cut the small zip tie anchoring sensor wire to the lower frame cross member.
Loosen & remove the 2 bolts holding the front of the skid-plate (1 each side), then loosen the 2 bolts holding the rear of the skid plate, no need to remove the rear bolts.
Swing the front of skidplate down & backward exposing wire bundle plastic sheath with the sensor connector inside.
Dig & push the sensor connector from the plastic sheath & disconnect it, then draw the disconnected wire back toward the sensor. Tuck the wire bundle back into position.
Unscrew the sensor from the footpeg/kickstand mount. Swing the skidplate back up into position & reinstall the front & tighten the rear skidplate bolts.
- Likes 1
Originally posted by Trail Blazer View PostIs there a tutorial on removing the the kickstand sensor?
Couldn't I just remove the kickstand and tie-rap or tape something to the sensor for now.
I intend to get the up-graded bash plate. When that happens I will then remove he wiring as posted above.
