Stan has a bicycle tubless tire plugging tool.
<div class="cards">
<div class="cardsFeatures">
<p><strong style="font-size: 1.8rem;">FEATURES:</strong></p>
<ul>
<li dir="ltr">
<p dir="ltr">Repairs large punctures and slices</p>
</li>
<li dir="ltr">
<p dir="ltr">Reacts with Stan’s sealant to form an instant, airtight seal</p>
</li>
<li dir="ltr">
<p dir="ltr">New woven, laser-cut material will not fray or pull out when riding</p>
</li>
<li dir="ltr">
<p dir="ltr">New sonically welded reinforced plastic tip for added strength</p>
</li>
<li dir="ltr">
<p dir="ltr">Wears off clean, no trimming needed, and can not be felt while riding, even on road tires</p>
</li>
<li dir="ltr">
<p dir="ltr">Lightweight, compact tool fits the shape of your hand for more precise use and includes built-in valve core remover</p>
</li>
<li dir="ltr">
<p dir="ltr">Includes two pre-loaded DARTs for sealing multiple and larger punctures</p>
</li>
<li dir="ltr">
<p dir="ltr">Clear caps keep DARTs clean and unthread quickly for fast deployment</p>
</li>
<li dir="ltr">
<p dir="ltr">Simple and easy to refill</p>
</li>
</ul>
</div>
<div class="cardsVideo"><iframe src="https://www.youtube.com/embed/K3n8lMgQmFo" width="426" height="240" frameborder="0" allowfullscreen="allowfullscreen"></iframe></div>
</div>
<!-- end cards-->
<div style="clear: both;"> </div>
<p><strong style="font-size: 1.8rem;">DESCRIPTION:</strong></p>
<p dir="ltr">We developed the Dual Action Repair for Tubeless (DART) to repair large punctures and slices in tubeless tires faster, easier, and more reliably than existing tire plugs. Unlike traditional tire plugs that attempt to press rubber strips into a puncture, dual action DARTs create both a mechanical and a chemical seal. The DART anchors into a puncture while creating a simple and safe chemical reaction with your Stan’s sealant to quickly form a permanent airtight bond. The DART’s patent pending ability to react with latex sealant makes tubeless tire repair fast, easy, and reliable for every rider.</p>
<p dir="ltr">Traditional plug tools were originally developed for car tires, and their long, sharp tips can cause damage to rim tape, or cut hands. Even worse, their plugs can actually expand many punctures because they rely on only a tight fit to hold them in place. In contrast, the DART’s sonically welded plastic tip and heavy duty woven material anchor firmly in place and stay put during even the most aggressive riding, while being safer for rims, rim tape, and your hands. The strong and flexible laser-cut material of the DART contours to different punctures and maximizes surface area sealing power. Because the DART anchors to your tire and creates a bond with your sealant, it also won’t pull out while riding the way a conventional plug can. One of the best features of the DART’s design is that it doesn’t require trimming once inserted, and excess material won’t get in the way of your ride. DARTs can’t be felt while riding, even on road tires, and they wear smooth naturally.</p>
<p dir="ltr">At only 15g complete, the DART Tool is designed to be extremely light, durable and compact to fit into pockets and packs, while offering an ergonomic design that’s easy to hold and allows precise DART placement. The DART Tool’s handle includes a built-in valve core remover, making it easy to add sealant. The tool is made of an ultra-strong but light molded plastic. Because even the small details are important, the rod that presses DARTs into punctures is made of ultralight, corrosion-resistant and incredibly strong carbon. The DART Tool is covered by a limited lifetime warranty.</p>
<p dir="ltr">Ease of use and rapid deployment were main priorities in the development of the DART Tool. Its carbon insertion rod is calibrated to let you insert DARTs to the perfect depth every time, just by pressing until the head of the tool contacts your tire. No more guessing games, or damage to rim or rim tape during a fast repair. The head of the DART Tool is double-sided and reversible, allowing it to hold two sealed DARTs on each side. This makes it possible to install two DARTs quickly when sealing the largest slices and punctures and even multiple punctures. Clear thread-on caps protect the stored DARTS, keeping them clean and ready to use, while being quick to unthread for fast deployment. The DART Tool packs all this repair capability into a compact shape that easily fits in any pocket or pack.</p>
<p dir="ltr">The DART makes tubeless tire repair fast, easy, and reliable for every rider.</p>
<p dir="ltr">DART Tool instructions available <a href="/media/wysiwyg/EIS-034_Stans_DART_Tool_Instructions.pdf" target="_blank" rel="noopener">here</a>. </p>
<p dir="ltr"><img src="{{media url=wysiwyg/Review-Graphics/DART-Tool-BikeRumor.jpg}}" alt="" /></p>
<p dir="ltr"><br />{{widget type="Magento\Cms\Block\Widget\Block" template="widget/static_block/default.phtml" block_id="93"}}</p>
