speed hacks for super 73 rose ave pls.
    Hello I am new here and have just ordered a super 73 by lithium cycles, it is a Rosa ave limited edition, I plan to mod it to go faster than the speed limiting will allow, but I know very little and want to do it right, any advice or direction would be awesome, thanks in advance, is there a chip? a physical mod that needs to happen? how can I do it i have seen a few videos and none are specific to the Lithium cycles, super 73 rose ave.
    That bike is not high voltage, not even 52v. For real high speed you would need to alter every aspect of the build including using a higher voltage battery and a high voltage controller and a direct drive hub motor laced into a new wheel
      Yikes sounds intense and expensive yikes
        Cool looking bike. You do get what you pay for and you are paying for 20 mph. You may be able to bump speed 5-10 mph with a beefier controller. 48V batteries can get you 30 mph in the right setting. When you burn out the hub motor with the higher power, you can upgrade to a more powerful hub.
          Another limiting factor is the rim size. 30 mph on a 48 V battery with a 20 inch rim is fairly unrealistic regardless of the current, especially if it's also fat bike
        You could easily upgrade the 500w motor to a 750w without re lacing the wheel then add a 35amp controller and lcd and change the battery to a 52v shark battery this will give you more speed/acceleration plus a lot more torque :) not cheap but a lot cheaper than buying a Super 73 2018 model and probably faster than one...... nice bike I am waiting for my Scout EU model in Jan/Feb and these upgrades are on my to do list :)
          Probably not worth it I was considering doing it if it was something easy oh well live and learn
          • Bheureux
            Bheureux commented
            What about adding a mid drive 1000w kit? 2nd battery, controller, etc.? The 2nd motor not connected to pedal assist?
