QS 205 50H V3 in 16” moped rim?
    I can’t find any info about fitting this hub motor into a 16” moped rim. Is the reason I can’t find any info because it’s not possible? I already have the wheel, but I’m awaiting the motor. I know that it will work in a 17” moped rim, but I’d rather stick with the 16” setup if at all possible. Any help is appreciated. Thanks!
    Answering my own question if anyone else ever asks...
    It will work. I got the motor and measured it all up. Ordered 91mm spokes and I’ll be lacing up when they arrive.
      I like to use Wheelsmith Spoke Prep for the spoke threads when I do that.
      I also like to put some oil in the rims where the nipple seats.
      I’m sure you will be doing a one cross pattern.
