Vibration at high speeds BBSHD
    I experienced several types of noise and vibrations within several weeks after installation on my Trek 7.2. First there was a clicking sound while pedaling and it turned out to be loose crank bolts. Second, there was growling and vibration under load but silence at PAS 0. This one was a bit scary because I could not replicate it with the wheels off the ground. It turns out that the inner BB lock ring was slightly loose and once I tightened it securely, everything was fine. It happened once again but this time I ordered the special wrench for the funky outer lock ring, tightened everything up to spec and it hasn't happened since. I have ~1,750 miles on the 750w rig with 52v triangle battery. I love this thing to death and recently set the battery gauge (DPC-14) to voltage in order to get a better idea on battery life--the percent gauge was darn near useless as it was always on 100% and once it started indicating less, power would quickly fall off a cliff.
      How do you like that top tube bag? Do you carry a GPS/phone in it? I have been thinking of buying one.
        I have 2 bbshd's. (1 from Luna, 1 from China) As I reach high rpm, they both start to vibrate, until I shift or reach my final gear. (I always pedal in 9 pas) One is a typical 8 spd.derailuer and the other, an 8 spd. IGH. Both act the same. I suspect loose tolerances in the motor's reduction gearing or a thrust bearing, but I just don't know. More an annoyance than anything.
          One of my BBSHDs vibrates at high load/speed sometimes. If I change gears, it goes away. So, I do that. It's worse with worn chain/cogs, so I rather think it's my chainline; I'm not convinced it's the motor, but maybe in some cases? I did think so, at first, but it wasn't really noticeable anymore with fresh chain and cogs, first time, a few weeks ago. This is a lower miles bike I haven't ridden as much, first worn-out chain, so not sure yet.
          • calfee20
            calfee20 commented
            My BBSHD does the same. It is definitely related to motor RPM. When it starts like you I upshift and it stops. Then as I go faster in the new gear it will start again, shift ,rinse, and repeat. It may be a loose bearing pocket. I don't know. I will have to tear it down this year. I should have done it already but I have been working on other bikes.
            I brought this up a long time ago and never got a reply and now that it is mentioned once in a while I get stubborn and don't reply but I have been seeing a few posts so here I am.
            This was my original description of the problem. https://electricbike.com/forum/forum...inor-vibration
          #20
          Downshifting works for me, too. changing torque changes side loads (thrust) on gear train, so could very plausibly indicate motor drive noises. But one worn out cog can be lumpy/noisy at some loads, too. Hard to separate, for me. Perhaps some of both.
          Worn nylon gear, too, probably could do this. A lot of drive issues show up as vibrations.
          I'm not worried about it, so far. I should probably take a look and re grease, before too long, I suppose.
          Interested in any causes found, and if any replacement or upgrades are known to addresse same.
