It appears the standard size BBSHD is out of stock at Luna and the build that I'm about to do does not need the 73-100mm (Fat) size. Couldn't I just add plenty of spacers to make a "fat" fit on a "standard" bottom bracket?
BBSHD Availability and Spacing
You can but note all the extra ends up on the left side. Normally things don't end up centered anyway and most people are not very sensitive to that sort of alignment so if you really want to go for it. Its going to be about an inch too wide. You often end up about 1/2" to the right so in theory this would put you a 1/2" to the left.
- Likes 1
Originally posted by 73Eldo View PostYou can but note all the extra ends up on the left side. Normally things don't end up centered anyway and most people are not very sensitive to that sort of alignment so if you really want to go for it. Its going to be about an inch too wide. You often end up about 1/2" to the right so in theory this would put you a 1/2" to the left.
I actually like how it turns out and using spacers on both sides allows me to fine tune the placement.
- Likes 1
OP, what do you intendto use the bike for in this conversion? Many people are not too sensitive to Q-factor issues for some applications. Serious road bikers often can't stand it, and serious mountain biking will possibly suck when you constantly jam your pedals into narrow obstacles on the trail. The application may or may not be an issue for you.
- Likes 1
