860C empty display
    860C empty display
    Hi,
    i bought an 860C display for my Prophete bike which has AEG branded Bfang mid drive motor. The problem is that the display has no image, but
    - backlight is working, when I turn it on
    - walking mode, pedelec is working when it is turned on
    …just the display is completely dark.
    can I somehow test it with bench power supply? I have a 24V bench power supply at home. It should work by applying xy voltage at right pins? I just want to test if the display is defective or not.
      If that other stuff works it does seem like its just a defect in the actual display part of the display.
        For Prophete brand, the display is customized. Not the public version. "Empty" means Wrong Communication. Not sure which ebike version you bought, e-novation? Here's info for your checking https://topeparts.com/product/sw-u-lcd-display/
        Focused on eBike LCD Display & Sensor scope.
