I recently ordered a new BBSHD and buggered up the retention spring that holds the pawls in place when installing the Lekkie Motor Cover. I removed the pawls altogether and continued mocking the bike up. Once complete (and without a working clutch) I took it for a test run on throttle power only. Worked awesome. I hit 31-32MPH on flats and 18MPH-24MPH up hills.
I went ahead and ordered another BBSHD and asked if they would go ahead and throw the Lekkie Motor Cover on it for me. They did. I just took out the first motor and installed the second motor. The problem is, I get massive resistance - even a grinding noise - when manually cranking by hand (the bike is in the air on a bike stand). The thing just does not want to spin freely. There is no way this is okay. Kind of bummed that I dropped an extra $1000 on a second motor and it showed up like this.
Wondering what the heck went wrong here? The Lekkie Motor Plate appears to be seated well. Guess I need to crack this one apart too?
Any suggestions? With the Pawls in on the clutch, should the cranks freewheel backwards with gravity? Meaning, if I hold up the cranks and drop them, should they fall back on their own?
