I'm wondering if I'm not reving the motor at times enough. I noticed when I was going up a short hill that the motor was putting like a "pulsating" flow of power and I had to stop. I noticed it again when I was adding throttle and about half way on. It was ok with a little bit of throttle but no more. The power cycles on and stops then repeats. Any ideas what it means?
Getting power from the drive but at times it give pulsating power not smooth
Originally posted by Retrorockit View PostWhat motor and what battery do you have. Maybe a 20A battery on a 30A motor?
A Dire Wolf can supply way more power than a 02 could ever use so its not like the battery is limiting things. I don't know the 02 that well but maybe its limiting things? If you were to try and pedal when its doing that what speed would you be pedaling? The BBS's like to be spinning at or even faster than the average person can pedal. If you try to pedal and you are pedaling slow you need to be in a lower gear or moving faster.
Originally posted by 73Eldo View PostA Dire Wolf can supply way more power than a 02 could ever use so its not like the battery is limiting things. I don't know the 02 that well but maybe its limiting things? If you were to try and pedal when its doing that what speed would you be pedaling? The BBS's like to be spinning at or even faster than the average person can pedal. If you try to pedal and you are pedaling slow you need to be in a lower gear or moving faster.
I'm not knocking the choice of a Dire Wolf, its a fine choice. Go big and stay out all day or go home early cuz your battery is dead. I was just saying an 02 really should not come close to being able to overload a dire wolf. Dire Wolf I think was designed for the Ludicrous option on the BBSHD which can pull a lot more juice than a stock 02.
If the pulsing is related to the combination of pedaling and throttle that may be a programming quirk. One of my 2 BBSHD's does do wacky pulsing if I sorta pedal while on the throttle and the other one doesn't so that has to be a programming quirk. I was going to try and fix it but I have just learned to not do that.
Originally posted by stts View PostAbout how many times do these pulses happen for each peddle revolution? Thats important to know to figure where the problem is coming from.
Originally posted by Bill B View Post
It happened during pedaling only when I did a massive hill climb, power setting three, and as I was down shifting the rpms were going down and it would pulse during pedaling. Normally pedaling works fine. The pulsing mainly happens with throttle. I thought at first maybe the motor didn't have high enough revs. So I kept down shifting but it still pulsed.
Yea, its a problem that is better shown in a video. So we see and hear the noises of the events. You say pedaling up a hill and throttle hard makes it happen. Without anything else, it sounds like the motor is not getting enough power. Like a failing battery connection somewhere or the actual controller in the bike having issues where it cant put out all the power the motor is requiring. The controller is inside the motor so if the big wires on the controller are having failing connection joints, it could also explain this erratic behavior.
