Hi,
I need your help and experience to install ebrake sensor on shimano M447 hydraulic brake lever.
As you can see on the picture below, pivot point for these brake levers are pretty centralized so the lever is very short.
I mean that if i glue magnet on lever close to the pivot point, I wonder if movement will be enough to cut signal.
As these levers are pretty standard, i'm sure that some guys have already find a good working way to install it.
Would it be possible to help me to find the best place to stick the sensor and glue magnet ?
Also, is it possible to test in situ the good working condition before to glue it forever ?
Thanks by advance for your kind advices.
Nico.
Nico.
