Voltage setting for 52v Luna battery
    I'm installing my first kit. I got it from Luna. Got the BBSHD - 52v battery. - color display panel. In the settings, you can choose voltage. It has 36 and 48. No setting for 52. Is it ok to use the 48v option? Not sure what I should do there. Thanks for any advice.
    Yes that's fine. We all use the 48 volt option. Just somthing to remenber though the display only ready to 56 volts but the battery is actually 58 volts.
      That's odd. I thought we were supposed to use 'UBE' for 52v batts.
        Guess I'll stick with 48 volts. Just wanted to be sure it's not going to hurt anything. Thank you.
