DPC-14 Color Display
    I have set the battery voltage to "UBE" which seems to be the setting for batteries that are over 48v but after that I don't see away to enter the 52 volt parameter. This new display readout is saying only 55.9 volts after a full charge and I know it's really at 58.6 volts so not sure why this is? Does anyone know why the display is topping out at 55.9 volts instead of the actual 58.6 volts? My volt meter and charger are confirming the battery is really at 58.6v from a full charge...........wayne
    Uncle Wayner, depending upon which battery charger you have (I have the Luna designed version with 80-100% charging capacity). I normally charge to 80% (54.2), 90% (56V) and 100% (58.5) depending upon which setting it is set to. Since Its nicer to the battery to charge to 80%, I only use 100% when I need to have a much capacity as possible.
