Basic Question on Mid-drives
    To date I have only built bikes with hub motors. I have a basic question about the Bafang mid drive. Does the chainring and crank spin all the time the motor is engaged or is there a one way clutch? It seems dangerous to me that the motor would drive the crank arms and pedals all the time? I guess if you only use pedal assist it is not an issue but I want an independent throttle.
    Thanks
    Robert
    There is a overrunning clutch between the pedals and the crank and there is another one between the motor and the crank - the pedal is a pawl style and the motor one is a roller style
      Thank you Sir! Do you know if there is a clutch in the Cyclone drives as well?
      Robert
        I've got no personal experience with cyclones but I'm pretty sure they do... there are plenty of cyclone guys around here that can confirm or dispel...
      Robert
      I believe it does and is incorporated into the chainring sandwich - and, there's a higher quality "Lunatick" upgrade available - https://lunacycle.com/luna-tick-cran...or-mid-drives/
