High Miles BBSHD Maintenance
    My BBSHD is starting to have two symptoms after 10,000 miles.
    1) Pedalling at mid to high power feels notchy. It sounds and feels like a bearing issue.
    2) The BBSHD isn't engaging at low power (PAS 1,2,3), but it sounds like it is skipping. Adding more PAS, or throttle forces the clutch to engage.
    This BBSHD has never been opened, and either problem might be solved with cleaning and regreasing. What would you do, and what parts could be needed?
    I would go ahead and buy the clutch-bearing and plastic primary gear. Get a tube of the right kind of grease, so...you can do the refurbish quickly.
    • Galroc
      Galroc commented
      I can't find the nylon gear on LUNA's site. :( Must be out of stock
      There is a thrust bearing but I am not see a clutch-bearing.
      https://lunacycle.com/bbshd-parts/
    Here's the nylon gear link and yes, it's out of stock currently: https://lunacycle.com/parts/bafang-p...eduction-gear/
    ... and the in stock currently clutch bearing: https://lunacycle.com/parts/bafang-p.../bbshd-clutch/
    BBSHD/BBS02B builds: 1 2 3 4 5 6
      If in Australia try pirezbikes in Melbourne.
      • Galroc
        Galroc commented
        Thanks for the suggestion, but in the USA
      Got to get normal - wear spare parts when they are in stock...
