BBS02 - something started limiting power to 500W
    Hi,
    BBS02 worked OK (with 750c display), i got around 800W will full throttle (max current limited to 18A) but suddenly i got only 500W with max throtttle even with PAS and level 9 i am limited to 500W also. Battery is OK i think because i dont get any significant voltage drop under load and capacity is still good. Also checked with programing tool that max current is still set to 18A.
    Something must be limiting current and it is weird it started sudenly without any change on powedrive on bike. Do anybody have idea where can be problem? I can drive bike OK with 500W but is good sometimes have power reserve,
    Thank you
    Jan
    Hi there. I have a similar problem. My bbshd is only putting out 500w max and it doesn't even feel like that much. I have tried 2 batteries, and I've checked the phase wires in the controller. Just wondering if you got yours sorted. Is my controller busted or is there a fix? Thanks.
      Link to video
      https://youtu.be/40kkzvz1jcU
          2 possible issues:
          1. BMS is bad (probably fried mosfet, had similar issue)
          2. Controller is bad
            Thanks. I've tried 2 batteries and they work fine on my son's 1kw hub. I'm thinking controller and am busy arguing with China for a replacement
