Nylon reduction gear
    What version should I buy? A? B?
    BBS02-MTR, Ordered March 2018 from Luna
    https://lunacycle.com/parts/bafang-p...eduction-gear/
    I can buy here only version B. if I dont click B, it shows error "This field is required". ???
    I tried to order via Paypal, it did not work. :(
    Why should I register to ask this question on forum. Do you have EMAIL?
    Like notated if you have an A you need 2 more parts. You can try support@lunacycle.com with your order number.
      I have version A. I cannot buy version A on Luna site. Do they sell it?
      or should buy Version B and two extra parts? is it worth it to replace to version B?
        The Bafang Nylon gear comes in 2 versions.  The old style mounts on a 10mm diameter pinion gear shaft and the new style mounts on a 12mm diameter pinion gear shaft. Please select the appropriate gear below.
