display shows 56.3v and doesnt drop
    the battery indicator shows full battery constant 56.3v - its a 58v battery with a dpc-14 display - the battery shows 52v after used on charger
    it happened after i changed the speedsensor to a new after the other speedsensors cap fell of and was kind of broken
    i did factory reset the display
    so i dont know if the bms is messed up or if its the controller or display?
    the display shows no error
    anyone know? its just constant 56.3v on display - if i do full throttle it goes down alittle then goes up again -when im done riding the charger says 49v etc
      https://electricbike.com/forum/forum...or-lcd-display
      I know it doesn't go above 56.4 on earlier models, but it seems like it should drop... Have it set to correct voltage?
