I already opened a new topic on this but since no response is coming, I also try here.
Brand new BBSHD + 965 + 30 mighty + Satiator from Luna and 52V battery, 15 Amp, 25R cells assembled 14S 6P.
Initially all was ok, First 4-5 miles great. Then accelerating and releasing the throttle, the motor continued to run. Turning off and then on again the controller, the motor stopped, but accelerating and releasing always kept running. Then the battery charge indicator of the C965 started to decline very quickly even if the battery was fully charged. Soon after, the pedal assistance has started to create problems; by pedalling the motor started but ceasing to pedal the motor continued to run. Something pretty dangerous ...Last issue, the display has failed. I mounted a new c965, the accelerator always had the same problem and after a few hundred meters has also marred the second C965. I mounted a 961, the throttle works, but with the assisted pedalling the motor is very irregular.
Please help.
Please help.
