Since I had already found a lot of reports about the fixed holder slipping down with time ( I thing this is a construction weakness of the system), I decided to take measures before having to deal with the problem and stabilize BBSHD from the beginning of the build: http://electricbike.com/forum/forum/...my-first-build.
In a boat shop I found a stainless steel Jaw/Jaw Tubular Turnbuckle T Toggle used in sailing and using washers I managed to fit it between the upper hole of the motor and the lower water bottle hole at the seat tube.
Check the clearance with the Battery in this last picture.
This turnbuckle provides very strong and presentable support for the weight of the motor, is adjustable in length and its movable joints makes it very versatile. Many bikes have already installed 5mm rivnuts at the seat tube or the down tube and if not it is very easy to install one at a convenient place in order to avoid using any hose clamps.
