luna giant bbshd clicking noise
    I have a 2016 luna giant with about 4600 miles on the bbshd and it just started making a clicking noise while pedaling and with throttle. I posted a link of what is going on. If any one knows what is going on please let me know.
    I would definitely open that motor up and do a investigation.
      It's hard to see, but is the chain jumping around when it rolls off the bottom of the chain ring? I wonder if the chain is worn out, although it doesn't jive with "just started", but not surprising if the chain has 4600 miles on it. Also, the chain is link-aligned with the wide-narrow Eclipse sprocket, I assume.
      BBSHD / BBS02: Nexus / Alfine 8: 1 2 3 4 5 6, Rohloff: 1 | PHOTON: Alfine 8: 1 2
        My bbshd was clicking after about 1000km and it turned out to be the motor mount needed retentioning. Remove the left side crank arm and the retaining nut then check the tension on the lock ring
