I'm not sure that my controller was re-programmed - at least I do not have a 30A limit that I thought the BSSHD was supposed to have - mine is limited to 25A, which I think is Bafang stock (??). Is it supposed to be 30A?
I'm finding that I can't get over-run the motor no matter how fast I pedal - I've probably hit 150-160RPM, but the motor is still pulling current, even in PAS1 - it seems to pull even more power when I pedal faster, oddly enough. I thought that the PAS assist provided power under a specified RPM, set to a percentage of max, which I was told was ~170-180RPM. My typical cadence is 80-90, but if I try to ride in a low gear, the motor overdrives my pedaling and I can't keep tension on the pedals. I'm finding that I can't ride in low gears unless going up a steep hill - I have to go about 18-20MPH on the flat, since the motor always is always pushing ~500W (7.5A-10A) no matter what I do.
In any case, I either don't understand how the PAS works, or the cadence target settings are WAY too high. Any suggestions?
