Lekkie Bling Ring 40 Tooth BBSHD Package Installation.
    I ordered a Lekkie 40T BBSHD kit that comes with a new cover and am trying to figure out how to safely remove either secondary gear/large/ or small bearing pressed into the cover.
    In my experience the only safe way is to press at the external race but it seems to be covered all but less than 1mm.
    Does anyone have any tips or tricks/order of operations to remove the Secondary steel reduction gear and bearing assembly?
    Side note, I was able to file down both the reduction case and main case with a file to get clearance for the 40T. Not sure why a CNC milled reduction cover was necessary anyways.
    Thank you for your time.
    How did it all turn out? I am thinking about getting that kit as well. Let me know how the bearing went and what else you had to do. Thanks, oh and pics if you got some.
