I'm following Cyclone 3kw builds online. And I ran into some builds where their BB/crank chainring was too far in. So they added a washer between the motor mount and the bottom bracket axle nut to push it OUT.
I can't do that on mine because mine is somehow too far outbound. I would just try to bend the motor mount into placement, but this is the thick motor mount we're talking about here lol.
It's about 1/8 inch off of so.
Am I not tightening the threads on the crank arm enough? Usually you don't want to over torque square taper crank arms, right? Or is this different?
I have the 68mm kit btw.
Thanks!
Thanks!
