Green Werks Yes the idea for the new controller is to test it with the Cyclone 3kW. I have to straighten out my battery issues. My current batteries are 6X Multistar High Capacity 6S 16000mAh Multi-Rotor Lipo Pack left over from my electric motorcycle project.
Most of this week I spent on hold waiting for bits and bobs to arrive.
I started work on a new project I am calling the Electric Bike Bullshit Detector. Currently it is just a hydraulic pump attached to an adjustable value and oil reservoir. http://www.staton-inc.com/store/inde...product&id=985 is a adaptor that will go from the 3/4 inch shaft to a stand bicycle freewheel.
The goal of the first step is to be able to connect a mid-drive motor to the pump using a standard bicycle chain. This should provide an adjustable load we can use to give us some indication of much the motor mounts and other drivetrain components flex under load.
If the system works I'll try to turn down a 7.5 inch quad v-drive pulley to use as a drive cylinder for a chassis dyno type system.
Ideally, this can become the brake for a simple chassis dyno that can handle Luna ebike levels of power.
But , first things first. :)
