HowTo - Install Cyclone chain with pictures
    The next steps are to install the cranks, chainwheel assembly and chain. Several builders have found aligning the chain to be the most challenging part of the build. Until you get some experience with the kit, you need to assemble everything in order to look at the chain line…. Then disassemble enough to adjust the spacers in the motor mount then reassemble again.
    We begin by installing the cranks. We will start with the left side. This build has a square taper bottom bracket.
    Click image for larger version  Name:	1.jpg Views:	1 Size:	511.8 KB ID:	27655
    The crank arms are pressed onto the square spindle by a single bolt.
    Click image for larger version  Name:	2.jpg Views:	1 Size:	619.3 KB ID:	27656
    Click image for larger version  Name:	3.jpg Views:	1 Size:	425.2 KB ID:	27658
    We repeat the process for the right side. The only difference is that the freewheel and chainwheel assembly are attached to right crank arm.
    Click image for larger version  Name:	4.jpg Views:	2 Size:	512.1 KB ID:	27659
    After the chainwheel assembly is installed, we will install the chain.
    In these photos, the chain guard on the motor has been removed so it is easier to see. You don’t need to remove the chain guard to install the chain.
    You can used a standard BXM chain available at any local bike shop. Start by wrapping the chain around the outside chain wheel and drive sprocket. Mark where to separate chain.
    Click image for larger version  Name:	5.jpg Views:	1 Size:	439.9 KB ID:	27660
    I have had the best luck by keeping the chain as short as possible. A short chain makes installing the chain a bit fiddly. It helps keep the chain from falling off.
    Use chain tool to split chain at the correct length.
    Click image for larger version  Name:	6.jpg Views:	1 Size:	639.6 KB ID:	27661
    Use the chain tool to press out the pin.
    Click image for larger version  Name:	7.jpg Views:	1 Size:	368.6 KB ID:	27663
    Leave pin extending from link.
    Click image for larger version  Name:	8.jpg Views:	1 Size:	795.0 KB ID:	27662
    Reassemble the chain and use the chain tool to press pin back into position.
    Click image for larger version  Name:	9.jpg Views:	1 Size:	531.6 KB ID:	27664
    Click image for larger version  Name:	10.jpg Views:	1 Size:	695.9 KB ID:	27666
    Install chain on the bike. Because of the short chain I had to remove the crank and chain wheel assembly to install the chain. Use zip tie to adjust tension on the idler sprocket.
    Click image for larger version  Name:	11.jpg Views:	1 Size:	508.9 KB ID:	27665
    If you have removed the chain guard, reinstall it.
    Click image for larger version  Name:	12.jpg Views:	1 Size:	545.8 KB ID:	27667
    The final step is to make sure the drive sprocket and the chain wheel are inline so that the chain is straight.
    Click image for larger version  Name:	13.jpg Views:	1 Size:	685.1 KB ID:	27668
    This example is straight. If it is not straight, you will have to adjust the spacers on the motor mounting bolts as necessary.
