Solder vs Crimp
If like many new e-bike builders, you use the forums to find information about how to build an e-bike you will soon come across a solder vs. crimp discussion. Many builders are passionate one way or another.
Let’s sidestep the passion. Like other aspects of building an e-bike, choosing how to make electrical connections is an engineering decision. Every engineering decision has strengths and weaknesses. Those strengths and weakness can be understood and weighed against each other. In some situations, there is a clear winner. In some cases, the best solution is less clear. I thought I could take a few minutes to look a few of the issues engineers use when choosing how to make electrical connections.
Quality assurance - In a situation requiring high reliability, the final decision often comes down to quality assurance. It is very easy to see if a crimped connection has been correctly made. It is more difficult to inspect solder joints. A solder joint may look good on the outside while note making good mechanical or electrical contact.
Installer skill and speed - With the correct tools, it is easier and faster to make good crimp joints than it is to make good solder joints. Soldering is a skill that takes practice and research to do well. Crimping is just a matter of using the proper tool to compress a connector into place.
Network, phone, and cable installers use crimp connectors. It is quick and easy to make high quality connections in the field.
Mechanical connection - The most often cited argument against solder connections is that when subjected to vibration they can be less reliable. To understand this issue we need to look at the physics of soldering. The soldering process involves liquid solder wicking between the components being connected and then hardening into a solid mechanical and electrical connection. In a stranded wire, the wicking action causes solder to creep between the strands of a wire.
Stranded wire is more flexible than solid wire of the same size because the strands slide past each other as the wire bends. If solder has wicked between the strands near the solder joint, the strands cannot slide past each other as easily as in unsoldered wire. The wire becomes stiffer.
This can cause failure if the joint is subject to vibration. The effect is particularly pronounced in automotive and marine applications. An engine vibrating at a few thousand hertz for 10,000s hours can wreak havoc with soldered connectors on thick wires.
Tools and consumables – The most significant advantage of solder joints is that nearly all small to moderate sized joints can be soldered with a $20 soldering iron and a spool of solders.
Crimp joints require properly sized connectors and tools for the specific application. Over time builders ends up acquiring a small inventory of connectors and surprisingly expensive tools
If properly done, the electrical conductivity of crimp and solder joints is so similar that designers consider differences in conductivity insignificant.
In most e-bike situations, the quality of the joint is more important than the specific type of joint. You will get more bang for your buck spending time in the shop honing your skills at make connections than participating in forum discussion about them.
- Quality Assurance
- Installer Skill
- Mechanical Connection
- Tooling and Consumables
- Electrical Connection
