My Cyclone 3000
    My Cyclone 3000
    Cool bike. So you've drilled a frame to create an extra support for the motor?
      No frame drilling.. Look closely at second picture. Took some square steel cut in half and drilled holes for the motor bolts to slide through. The hose clamp slides through elongated holes drilled above the bolt holes.
      I used the thick aluminum mount with the kit on the right side and made the left side with slightly thicker aluminum from the scrap bin at the local machine shop $5 (Pic1). Rigid Light and clean.. no flex or chain drops.
