"Edge" 1500W DD hub with 35mm wide stator, thin laminations, aluminum core
    C-20 I emailed him the other day
    His web site shows that he has A edge in stock laced on a 26
    but when I asked about the availability of the edge and a 18 fet controller
    he said that he would have to get the motor
    let me know how you make out.
    • calfee20
      calfee20 commented
      That is what I ordered. Edge on a 26" wheel.
    #92
    C-20 any word on the Edge
    • calfee20
      calfee20 commented
      I got a reply to my email. He said he was out of the country and he promised to ship yesterday. It sounds like a one man band.
    #93
    C-20 I am sure he is a one man band but he has some great tunes
    I emailed him yesterday to order a 18 fet controller he said he had them
    but the web site says they are out of stock we will see
    I look forward to trying out the new 18 fett and see if it improves my efficiency
      Gust ordered a ERT 8000 W 18 fet sine wave controller For the Edge going to replace the 12 fet
      and see if I can turn the heat from the 12 fet into energy with the 18 fet
      The hunt for distance goes on so far 54 miles with battery to spair no peddling
      Cheers Bill GW https://electricrt.myshopify.com/col...ller-18-mosfet
        I just got an email confirming my edge shipment. I'm glad I decided to wait until Monday before complaining. I hate to be a PITA even when I have cause.
        I am pretty sure I will go with this controller. http://em3ev.com/shop/12-fet-irfb307...on-controller/
          C-20 good Deal on the edge
          tracking says that my controller will be here Monday
          I checked out the controller you want looks nice let us know how it plays out
          Cheers Bill
            Got the new 18 fet controller plug and play
            This controller is powerful there is a difference from the 12 fet
            cant wait to ring it out
              Click image for larger version  Name:	 Views:	2 Size:	402.1 KB ID:	37110
              Click image for larger version  Name:	 Views:	1 Size:	590.0 KB ID:	37072
              12 fet controller
              18 Fet sinewave controller Beast
                Click image for larger version  Name:	 Views:	1 Size:	296.8 KB ID:	37117
                Click image for larger version  Name:	 Views:	1 Size:	282.9 KB ID:	37118
                Update: Surprise surprise surprise
                Went out for a little test run
                I was able to hit 43 mph and using only 34.94 amps
                with the old controller 12 fett I could hit 38.1 mph but I used 50 amps
                If you look at the old posts you can see on the CA
                I thought that this new controller felt stronger and maybe that was just wishful thinking
                but the numbers show that it is WTF this one has me any thoughts Spinning Magnets
                  Figured it out The shunt value was off in the CA was told that it should of been the same as the old 12 fet controller
                  1.6 ohm but it is not, I got it sorted out now back to the test runs to get some new numbers this controller
                  does not even get warm we shall see.
                    C20 whoo day dude Do U have the Edge
                      Wow it took me a while to find this page again.http://mrbill.homeip.net/hybridBike.php Here is the recumbent he drives.
                        C20 where did that motor come from
                        I am on the hunt for info
                          Hi Bill, I did a good deal of searching on alibaba and google. I came up with a few leads. Afterwards I was contacted by a company about a motor you might be looking for. (Not 100% sure it's legit yet.)
                          I'll send you the info in a private message.
                            Thankx Dude I will look into it
