Which sensor is this?
    Hello, I want to change the sensor in the hub motor of my electric bicycle, but I can't find it, which sensor can you help me? Hub motor RKS RS3 Pro X 250w 36 Volt 20inc wheel
      Hello, the blue one is the signal hall, normally mainly in the integrated board, they have three, what model is not important, the important thing is to install it can run normally, the red one is the speed hall, you display on the display whether the speed display depends on it, there is only one, if you need I can help you get it!
        Hello yes I need it but I live in Turkey I can buy it from the sellers here but the hall sensors used for signaling purposes are defective, which one should I replace it with, is there a hall sensor you recommend?
