Edge 1500 on an Electra Fat
    Nice build man! You must have built a few bikes, it looks real good. I am totally new and for my personal bike I am looking to get a set up like this. I am just to green to jump that deep at first. But I am def going to go back thru your thread to get info. Maybe I can find a builder here in FL to help me put the parts together.
    • calfee20
      calfee20 commented
      I'm in the Tampa area in the winter.
    #47
    I am just north of orlando all the time. Lol. I need to become a snow bird thou. I have played a few shows at the amphitheater by the hardrock.
      Originally posted by calfee20 View Post
      The only explanation is the center strip on the tires that the bike is running on and maybe I have hit on a perfect combination with this motor winding and tire size. I can pedal this bike at 25mph with 500 watts of assist. It does not make any sense but I love it.
      Calfee20, what is the motor winding on the MXUS 3000?
      • calfee20
        calfee20 commented
        It is a 5T
      #49
      Well I needed to do some maintenance before Florida this year. The bike also had a clicking in 4th and 5th and the chain would hit the tire in 7th so I ordered a new derailleur. I also have an eight speed freewheel that I will use the top seven speeds and leave the largest sprocket like a spoke protector. I am going to change my spacing in the back to see if I can get my seventh speed back.
      I am also going to abandon my tubeless tire setup and go back to tubes with Stans in the tubes.
      Well this was a good upgrade. The new derailleur and chain are working flawlessly and my chain is just barely touching the tire when I am in first. Both up and down shifting while pedaling feels like an automatic. Shifting while pedaling keeps the power uninterrupted and the flow of the ride is much better. This bike is ready for Florida now.
        kauaicycler commented
        1 day ago
        "I'm interested in doing a mxus build for this bike. I've read your threads a couple of times and I don't see where you mention using any torque arms. What did you do to secure a big hub motor in an aluminum frame or is your frame steel? The current Lux Fat Tire 7D is aluminum. Thanks!"
        Comments can get lost in the weeds so to speak and I almost lost this one. It is better add an entry or quote something because it shows up better. Anyway torque arms.
        When I had the Edge on the bike I used Torque arms made by Grin.
        https://www.ebikes.ca/shop/electric-...orqarm-v4.html
        I only used that piece that fits the axle. I put one on each side and I pushed one forward and one to the back and drilled a hole in each flat rear dropout plate for the nut and bolt. Then when I switched to the Mxus motor those arms didn't fit because the axle is larger. It is still 10mm across the flats but it is 2mm larger in diameter or 16mm. So I bought arms from West coast cycle.
        https://west-coast-electric-cycles.m...-m16-m14-axles
        Then Miracle of miracles the holes I drilled for the other arms perfectly lined up..
        After building several bikes I have decided that you should get your rear wheel spacing, freewheel, chain, and all correct before you lace your wheel. Then you will know exactly how to dish your wheel. The factory bike had 26 X 3.5 fat tires and then when I changed to 26 X 4.0 knobbys my chain was hitting the knobs. Those torque arms can be used as spacers on either the inside or the outside while you are setting up your stack.
        Everything was fine until I got my regen working. The 45 mm Mxus motor produces an insane amount of braking. It was almost like slamming on the brakes without dragging the rear wheel until I toned it down by reprograming the controller.. The constant change in direction of the applied torque had the axle nuts loosening up. there was a lot of creaking going on back there. The answer to this problem came from Mr. Bill over on endless sphere.
        https://mrbill.homeip.net/index.php
        I installed a couple of "NordLock" washers and tightened the heck out of the axle nuts.
        https://www.amazon.com/Wedge-Locking...6719903&sr=8-1
        I also got a decent set of axle flange nuts instead of the crap that comes with the motor.
        The regen is worth all of the trouble it caused. 95% of my braking is done with the micro switches built into my brake levers. I will see if I can get a couple of photos tomorrow if I don't forget......calfee
        PS I'm thinking of building another one. Only with the Tall steel frame and a 6T 35mm motor. The tires will be Schwalbe 2.8 X 27.5 Super Motos. There may be some welding involved on the rear dropouts and the head tube for the suspension fork. I have ALL of the parts except the frame. A new tall cruiser in steel is less than $400. Right now this bike is in my head. We will have to see if it ever gets out.
          This is the right side of course.
          Here is the other side. Those extra hole are the remains of that 5 speed Sturmey Archer installation.
            Here is the bike on the beach at Fort DeSoto park south of Tampa near St Pete.
            Blue water Blue sky, this was a great ride. It was a little short though at 12 miles and it takes me an hour of driving to get here from where I am staying north of Tampa.
