Thudbuster 3G LT
    Thudbuster 3G LT
    Having just purchased unused 2nd hand Thudbuster which came with two #5 elastomers fitted, would it be ok to exchange on of the #5's for #9 for my weight if 108kg or is it better to use two #7's. Both combo add upto 14 if thats anything to go by. Thank you.
    The Thudbuster manual has all of the information that you require for weight specifics in it.
    http://www.canecreek.com/wp-content/...11-2013-v2.pdf
      With mine I found going 5 and 7 works well although it's rated way above my weight at 89-98kg - I'm 70-75kg
      I also put in a fair bit of preload - likely more than most
      I do a lot of rough stuff
