My 1500 watt NBPower direct drive hub motor needs to have a hall sensor replaced. The sensor appears to be 613806. I can't locate any sensors with that number. What should I use?
Hall sensor replacement
The hall sensor is an electronic switch, on or off. All three work the same and as such their electrical properties (type) should match if your thinking of replacement. As such you can move the sensors themselves to any slot.
But their positions also correspond to which phase(s) of the motor's windings are in a certain position. ( 3 hall sensors, 3 motor phase winding) Which is given to the controller by it's associated wire and how it's sequenced into it. This allows the controller to operate by energizing the correct windings at precise times to make the motor spin.
Is this to do with an error 07? ;-)
Regards,
T.C.See my completed Magic Pie V5 rear hub motor E-Bike build HERE.
Thank you so much for your response. Im just not sure if its the hall sensor or what . It comes on normal then when i turn the the throttle nothing and if the wheel moves it then shows an error on tje display and the number 07 and i dont have the manual purchased thru Amazon its a Goplus 1000 watt 48 volt front hub drive conversion kit.
I will just stick to this thread... see you there.
My 1000 watt front hub brushless motor has stopped working. When i turn on power it has a full 48 volt showing 54 volts the display looks normal then if i spin the wheel in any direction just a pinch it error faults with a number 07. The motor was purchased thru amazon by Goplus? What could be causing this ? Any help would be
