Hub wheel not spinning ?
    My 1000 watt front hub brushless motor has stopped working. When i turn on power it has a full 48 volt showing 54 volts the display looks normal then if i spin the wheel in any direction just a pinch it error faults with a number 07. The motor was purchased thru amazon by Goplus? What could be causing this ? Any help would be greatly appreciated. This is my only transportation. Thank you..
    The first step would be to verify what an error 07 is... (Lol captain obvious... referring to me :-) What does your display manual say? Particulars on your equipment (display, controller, motor, and battery) may eliminate unnecessary questions.
    Regards,
    T.C.
      Thats my problem i do not have a manual or anyway to id these codes i purchased thru Amazon it is a Goplus 1000 watt 48 volt front hub drive i have a brand new 48 volt lipo battery. And the controller is the one that came with the conversion kit. Please excuse me im just now learning all this stuff and its quite frustrating not being ablr to figure out why this is happening. I attempted to see wha5 was going on inside and notbing seems to be bad. But when i power it up it comes on like normal but the secind yiu move the tire it error faults to a 07. And i dont have the manual it came with was garbage to begin with and emailed amazon and goplus for a manual no replies.
        Inadequate included documentation seems to always be an issue! No worries. Does the display have any numbers or markings on it? (IE; KTLCD3 or C300S) Would you be able to post a picture of it? Would you be able to provide a link to your kit? Any other information... we have to sort the error code first.
