Squeaking motor
    Squeaking motor
    I got my wife's trike with a dual gear hub running great thinks to all the crew at Luna. We went on are second trip today and When I was putting her bike's away after a 10 mile trip today. I noticed that the hub motor has a slight squeak. Any suggesting with this ?
    That could be coming from any number of areas, you'll have to be more specific.
      The sound is coming from in side the hub motor. If I remove the screws on the side of the motor. Will that allow me to remove the side cover. Inturn that may help me see where the sound is coming from .
        In the video on the listing it shows how the cover unscrews. Those 3 bolt holes on the side you gotta get m5 bolts in and use something to twist it off. user bleedpurple figured this out yesterday:
          Thanks Paxton . I opened up the motor and tracked the squeak to the roller clutch. I applied a small amount of grease to the race and roller clutch . that took care of the squeak. Thank you for the information on open the motor. That was a big help.
            In the video on the listing it shows how the cover unscrews. Those 3 bolt holes on the side you gotta get m5 bolts in and use something to twist it off. user bleedpurple check this out yesterday:
            It's clear now. Thanks!
