I am mounting this hub to a steel fork with a disc brake mount. I only had to spread the fork a skosh (able to do it by hand) to get the dropouts over the axle flanges, but there is no way the disc brake caliper mount will clear the disc itself. I have three different disc brake calipers in my kit and none will clear the disc. Has anyone else run into this problem?
Double Torque/Double Gear gearmotor hub Disc Brake mounting problems
You didn't post any photos, and I can't tell how much experience you have. So I'm going to guess. Normally forks have an industry standard mounting that requires an adapter to use various disc brakes. The adapter must match the brakes. The adapters also vary with the size of the rotor used so there are many differnt sizes. Rear adapters are different than front ones. 2x more adapters for that.
