MP5 on delta trike
    MP5 on delta trike
    Has anyone installed a Magic Pie on a delta trike?
    Anything I should keep in mind?
    I'm not sure the extensions exist to make that work on a trike if you need extra length for the cabling like wiring harness throttle etc.
    but assuming you have that worked out or plan on just splicing extra lengths of wiring in then you probably want to keep in mind you need a torque arm on both sides
