BBS02 Program Cable and Magic Pie (Vector) Cable
    Does anyone know if the BBSxx Cable would work on the MP Vector Controller? They both are the same physically, number of pins, etc. but not sure about the pinouts. I wanted to use my BBS02 cable on my MP Edge (Vector) Controller. Here's the link to the MP Vector cable:
    https://www.goldenmotor.ca/products/...ntrollers.html
    The pin-outs are different and they will NOT work with each other as built (leaving the option open to re-wire as needed, I believe communication hardware requirements are the same...)
    MPV5 uses the 5 pin motor harness connector.
    Bafang uses 5 pin display connector...
