How to fit a Shark Pack onto the down tube, if the bottle screws do not line up.
    Hi Guys
    I thought it was important to create a thread to help when you are having issues installing battery's onto the down tube.
    This way you do not need to drill extra holes into the down tube and use Rivit Nuts.
    I run into the this problem yesterday when installing a battery onto a bike with a very small triangle.
    1. First remove the 3 screws from the plastic battery mount and place somewhere safe. Click image for larger version
    2. Line up both the aluminium plate and the plastic mount with the frame to determine the position for drilling the hole into the plate.
    3. After drilling the hole though the steel backing plate I then replaced the batteries plastic cradle. As you can see in the photo below I needed a counter sunk bolt to allow the battery to slide into the cradle. Click image for larger version
    4. Below completed battery fitted and as you can see its a tight fit but it does slide out by lifting the rear of the battery first and sliding sideways and allows you to mount a battery without the need to drill into the frame and use Rivit Nuts. Click image for larger version
    Rodney64
    Giga Member
    no pictures are coming up.
      Pictures now, thanks.
        Ok Guys, I have had a customer email us at support and recommend the water bottle cage adaptor. This is an easy way to help make a shark pack fit without the need to drill the plate in the above procedure
        https://mountskidmore.com.au/shop/ad...-cage-adapter/
          If anyone else is having a similar problem, first check out this quick video from Luna Cycles:
            yeah second that on watching the above video.... its a more solid mount when you mount like this even if the mount fits normally.
              I've also mounted using the aluminum plate which works fine. However I still plan to drill two additional holes and use rivit nuts for these on the front of the shark mount. Currently the pack vibrates on the front which makes some noise.
                Was just stressing out because this is what it looked like I needed to do. Need some more of those rubber tube stabilizers though. Probably will zip tie the from till I get guts to do the rivit nuts to my aluminum frame.
                  If anyone knows where I can get some of those please let me know.
                    now I know what those are for, mine came with an empty shark pack I bought for spares
