Edit: The underlying fundamental question is...can the charging port of an ebike battery pack be used while the battery pack is being used to ride about?
What do you think of this idea? I make a small current limiting circuit and put this current limiter on the output of 36V pack#1 (say...limit to 2 to 3 Ampa), and then use freshly charged Pack#1 to recharge 36V Pack#2 through it's normal coaxial 2Amp charging port WHILE it is in use on the ebike. This is not putting the packs in parallel...this is using one pack to charge the other while it is in use.
The problem is that I am just beginning to study ebike BMS/charging/operation circuits and don't know if they are designed to prevent charging while a battery pack is in use.
I also don't know what (if anything) REGEN designs disable while charging the battery pack with the bike in motion. So would the viability of what I'm suggesting change depending on whether or not the bike uses regen?
Or, I suppose I could even use a higher voltage battery for Pack#1 and just use a current AND voltage limiter set to 2A/42V.
Edit to add: Explaining the whole reason for thinking about this, is that the existing battery pack uses an integrated output connector (no harness) that slots into a mating connector integrated directly into the bicycle frame. This is an attempt to avoid having to cut open the original battery pack to substantially modify it in a way to allow paralleling the outputs of the packs.
