Battery key blanks for dolphins and sharks
    I wanted spare keys. I searched and didn't find anywhere which blanks to use so I worked with local hardware stores and came up with blanks that work for dolphin and shark packs. On the left are dolphins that used a Honda blank, in this case Hyko HD75 and the on the right is for a shark and we used a Toyota blank, in this case a Cole T020.
    Either one would probably work in both. The first guys gave up after fitting the dolphin - they got hung up on the extra slot that runs up the key face but the second guys figured out it didn't matter...
    AZguy
    Giga Member
    Great info and since these are fairly simply tumblers key impression techniques might be of some use:
    https://www.youtube.com/watch?v=jciQpGdAVtc
      From what I can tell, they only have two tumblers, maybe three, and they're pretty loose... keys cross over much easier than you might think ;-}
        AZguy
        Giga Member
        And bring the battery with you to the guy that's fitting the key!!!
      Thank You for this Info. I have a Luna Battery and the REENTION keys have plastic "tops?" and it broke off my key chain. I have the spare key and will go the hardware store and make more.....Oh...and bring the battery! Thank You again !
        Thanks very much for this info on the key blanks. I have moved the thread to the knowledge base section.
          Dales Hardware uses a computer to scan key and reccommends what type of key to use . HD75 worked !!
          They say its for Honda Motorcycles. .again Thank You Very Much
