15S/10P Li-Ion NCR18650GA Battery Build for Enduro E-Bike (BBSHD Mid Drive)
    Building 15S/10P into 2 x Battery Packs- Pack 1: 8S/10P & Pack 2: 7S/10P (NO BMS REQUIRED !)
    Charging & Balancing done using an I-Charger 4010 Duo, Charge to "4.0v per cell" giving "60v Total" (this will increase Cell Cycle life span from around 500 Cycles up to 1,500 Cycles" !!) and increasing Voltage by 1.8v Total,for a little added "PUNCH" on my BBSHD Enduro E-Bike Mid-Drive Build (11 Speed, Front Sprocket - 46T Lekki Bling Ring HD / Rear Sunrace Cassette - 11-46T)
    Custom Charging/Balancing Sockets installed on EEB Frame for Quick Plug in -"Charge & Balancing" with out any side panels being removed or wiring Disconnected. Wanting an "Easy Plug & Play" type Setup.
    Battery Packs can be electrical isolated from series connection for Charging/Balancing using a Solid State Relay (operating off a 3S/3P Aux. Battery) controlled by a 3 position Ignition Style Key Switch
    Note - Photos Below show various levels of Assembly & Construction Methods ( Hope they are useful for any one wanting to build in a similar method)
